making a heavy loft hatch door safe
JP_
17 May 2012
I bought a custom made loft hatch. It's made of metal and insulation. A great fit, well insulated too. But, much heavier than I thought it would be. A bit treacherous when opening it, and also a bit iffy when closing too. And it will only get harder as I get older....
Any suggestions on how to make it open slow? I did see these, that might work if I can safely attach into the metal door, but these are a bit expensive. I have contacted the company I bought from to see if they have anything, but can't seen anything on their site.
A counter balance might solve the problem.
Add the red bits to form a counter ballance.
Maybe, but it might stick up in the way when open? I guess not a problem with the size of the hatch... Actually, it will have to be right on the side or it will get in way of ladder.
use a bit of design and it will provide a hand steady for the top.
My old hatch had a spring like a gate closer to help it
A rope attached to either front corner running up through a pulley above with a weight added, a bit like old fashioned sash windows? Like the diagram but the other way round perhaps?
The guy that helped me fit it suggested weighted pulley. Need to check what fixing options i have.
You wouldn't be able to lift your car hatchback tail door without the assistance of a pair of gas struts......any future in them?
John :)
That is the sort of thing, but that particular one has only 50mm of movement.
You may be surprised at how powerful these things need to be - sorry I cant advise on which to choose!
John :)
Thanks, I'll keep searching, and get the tape measure out. I just searched for 25kg thinking that would be sufficient, maybe I'll go 50kg next time....
It could be a good move to get a car tailgate strut from a breaker, and experiment with that - you can always double up if its not strong enough.
I've fitted a small one to an up and over kitchen cabinet front and it hardly made any difference :(
John :)
John :)
Gas struts are intended to hold open doors, not aid opening .
