- Joined
- 31 Aug 2016
- Messages
- 16
- Reaction score
- 0
- Country
I'm looking for a new boiler as my Alpha CB50 Combi is leaking from the DHW storage cylinder and its apparently prohibitively expensive to repair. I find the Alpha fine in terms of CH output and DHW - the manual rates it at 28 kW for both.
The guy that services my boiler recommended a W-Bosch 38 CDi Classic Combi as a replacement that would be able to match the DHW output of the Alpha without going down the route of an unvented cylinder. However, I'd read a lot of positive things about the Intergas boilers so I found an installer to quote me on one of those. He recommended the Intergas HRE 36/40, at a much lower price than the W-Bosch. However, I am a little concerned about the DHW output. As stated the Alpha I currently have has a small hot water cylinder built in so it copes pretty well with a shower and a tap running at the same time. With the Intergas I wouldn't have the thermal store so I'm wondering how it would compare? The specs on the Intergas website state 18 l/min for a rise in water temp of 25 deg C. This seems pretty decent on the face of it, but comparing it with the W-Bosch 38 CDi it doesn't look that great. The specs from each manufacturer are presented slightly differently but based on the input kW for each I calculate 13l/min for the Intergas and 16l/min for the W-Bosch for a delta T of 35 deg C. Question is, is 13l/min enough to match the output from the Alpha? If anyone is running an Intergas combi with multiple showers I'd love to hear your feedback on how it performs!
Also, the CH output of the Intergas is a lot higher than what I currently have at 40.9 kW. Seems overkill but the next model down outputs slightly lower than the Alpha at 26.6 kW so may not be enough. I live in a large 4 bed victorian terraced with a bathroom and an en-suite and the Alpha seems fine.
For the Intergas is it recommended to fit a magnetic filter? That seems to be missing from the quote.
I'm also waiting for quotes to come in from both installers for unvented cylinder options but I believe this option will be much more expensive. I'm also looking at a couple of other storage combi options, the Vailliant 938 and Viessmann 111-W.
Thanks for taking the time to read this! If you have any useful comments or advice I would much appreciate them!
