Hi, would be grateful for wiring advice for my Hive multizone set up.
I have a Worcester Bosch Greenstar 35Cdi system boiler and separate hot water tank with multizone thermostats (upstairs and downstairs). The boiler uses 230v mains switching. The boiler is currently connected to 2x Center BDR91 relay boxes, which in turn connect wirelessly RF to the two battery-powered EHE0200361 programmable timer/thermostats in each zone. There's also a separate Honeywell hot water electronic timer.
I want to replace this with my Hive set up. I have purchased a dual channel Hive Heating and Hot Water thermostat, plus a secondary multizone (single channel) thermostat.
The two existing receivers are currently wired exactly the same - fixed live and neutral (blue and brown wires), black wire to A, grey wire to B, earth unused.
For the single channel Hive receiver, I think this is simply a case of wiring up the L and N, and then black to 1-Common and grey to 2-NO (Heating On).
But for the dual channel receiver, there is no Common - do I connect the black to 4-NO and grey to 2-NC (Heating off)? On some threads I read that I would need to create a link between Live and NC - is this the case?
Many thanks in advance for any advice you can offer
(by the way I don't intend to hook up the hot water control to the Hive as the existing hot water timer works fine and is located some distance away so will be a pain to move the wiring).
