HIVE Multizone
16 Sep 2014
Essex
Hello
Can someone clear this up for me please, Is it just the name or what?
If you have two or more heating zones in a property, you will need:
Zone 1:
Hive Hub connected to a receiver paired to its thermostat.
Zone 2:
Hive receiver connected to a receiver paired to its thermostat.
Once connected, the thermostat will communicate with only its paired receiver.
So what is HIVE Multizone?? is it just called Multizone because you don't get a hub with it or is the multizone thermo stat different in a way of its functionaility? As it stands, if both are paired up to its own receiver then to one hub, it can be controlled via the app etc.
7 Jun 2009
Liverpool
Basically, yes, two thermostats, two receivers, one hub. All controlled through the app. It’ll just show as zone one and zone two until you rename them. Multizone is just the name given to identify the set up.
