Smeg SY93, main oven not working
14 Sep 2010
Rochdale
Hello, I wonder if anyone could help?
I just found the main oven (bottom left) isn’t working. The grill, tall oven and hob ignition all work fine.
This is the oven:
And the 2 controls for the main oven:
The electric to the whole house was turned off for 30mintes earlier while a socket was fitted elsewhere in the house.
Any ideas? Thanks :)
It works again now, must have been something to do with the clock because once I set that it worked again
It is a failsafe, that ensures the oven will not heat up when power is reconnected after a power cut even if the controls were left set that the oven should heat up.
Setting the clock ensure as human is aware of the situation of restored power.
