I need to:
Question: Is this Part P notifiable? The table of "What needs to be notified" shows kitchens under the "Minor Works, Extensions and Modifications to Existing Circuits" as NOT notifiable. But I see chatter on forums suggesting otherwise.
- Blank off existing switch - fitting sufficiently rated connector strips (45A?)
- Extend the existing cable using a sufficently rated wall mounted junction box.
- Cable will run under floorboards.
- At new cooker position run cable up wall to new cooker switch. Cable to be plastered over so assume steel capping required?
- Run connection cable down same capping to cooker connection outlet plate.
- Connect new double oven (4.5Kw rated).
