There’s no insulation under the rafters.
If you do drill the holes and foam it i’d recommend you get a foam gun, they are much much more controllable that the cans with a nozzle on.
Sounds like you’ve had a tough time with it![]()
celotex is not the ideal insulation to prevent drafts as it’ll never be cut to perfection.
but can get a proper gun and can if that’ll help do a good job!
Already bought some no nonsense foam that I was going to use on the skirting and other holes but can get a proper gun and can if that’ll help do a good job! Anything in particular you suggest or is any gun and foam fine to use? Could get something from amazon or screwfix/toolstation. Thanks!
