Exactly - but I wouldn't really call that 'putting a spanner in the works', since it's really the same point I was making. Mind you, it's not justthose who write regulations - we see plenty of electricians and others, here and elsewhere, convinced that 'all-RCBO' is the only way to go - but, as I asked, is that "just because we can" (and thereby save a little inconvenience)?I'll put a spanner in the works by saying that the people who write the regulations just appear to have an attitude that that they can write whatever they want with no regard to the expense being justified or not. Two billion pounds could save a lot more lives if spent in other areas; e.g. the roads. If they are that important, why not make them statutory?
Indeed. I imagine that many/most of us assume that it's only a matter of time before they make it 'simpler' - by just requiring everything to be RCD protected. As you are aware, I have been known to question whether RCDs, even on 'high risk circuits' have actually saved an appreciable number lives, and that becomes a bigger question (to be balanced against cost) if, as is almost the case, everything has to be RCD-protected.Also, is the creeping coverage of a bit more regulation with every edition. Firstly, RCDs were a requirement for sockets likely to be used for outside tools - fair enough, I suppose - but then it is for concealed cables - which, in effect covers just about everything unless installed intentionally to negate this, then all sockets - even upstairs in wooden-floored buildings, then lighting circuits are included.
Exactly my point - although I was talking about the 'trend', not the 'mandatory' which might well eventually show its face!A demand for an RCBO on every circuit would do nothing more for electrical safety - merely cause less inconvenience (if you want that, then you can have them fitted) so, in my view, would be a step too far and over-stepping the remit of the regulation writers.
Indeed. It reminds me of one of my personal hobby horses about seat belts - which are a safety issue. I have been a fairly fanatical supporter and user of seat belts since before their existence (let alone use) became compulsory, but I have always being opposed to compulsory wearing of them by drivers and front-seat passengers. I just don't understand why a society (Nanny State?) which allows people to climb mountains, creep around in pot holes, jump out of aircraft etc. makes it illegal not to wear seatbelts - since non-wearers are only putting themselves at risk. It's a bit less straightforward for back-seat passengers since, if unrestrained, they could 'fly forward' in the event of a collision and harm those in the front seats.There are a few other regulations which have nothing to do with electrical safety - merely a good idea anyone could do if they wanted -therefore they should not appear in the electrical regualations.
