Hi all, been browsing here for answers but struggling to find the correct answer.
I am trying to install a hive dual channel system for hotwater and heating. I had a look beforehand as a fairly confident DIYer. This job looked like a fairly simple task of installing the programmer to replace my previous drayton unit. I was pretty chuffed with myself when I had all of the system running until I got to removing my current Honeywell T6360B for some unknown reason I believed it would be a straight in and out job until I saw the wires connected to the unit.
After hours of googling around I understand I cant just disconnect the cables and hope it would all work.
Options was to try bridge the two cables which hold and live and live switched which are from pins 1 and 3 on the room stat. Which I have tried with no sucess but I want to do it properly and disconnect the cables just because I have no space to push behind to hide any block/wago connectors.
I'm struggling to isolator these cables i've got the blessings of having a cable toner with a wand which ive borrowed off my mate. I have a wiring centre located in an airing cupboard but i'm just baffled by the amount of cables.
Wondering if theres an easy way of locating these cable to try bridge the who cable points to remove the thermostat from this equation.
Attached as pictures of the thermostat. Behind my programmer there is a block connector which has a 3 core cable with earth which i believe goes back to the room stats but one of the cables goes to pin 4 which if i was to disconnect would the hive from working correctly.
Pleaseeeee help
Pleaseeeee help
