Connecting Hive Thermostat to Ideal Boiler
Did you take note of the number of pins that were on the plug for the receiver?
The one in your link has 8 pins, whereas yours may have 3?
The number depends mostly on the age of the boiler.
What is it's model number?
Ah, correct! Is a 3 pin plug and Logic+ Combi C30
In terms of being porous also, is there anything I should do to prepare before taking out this receiver other than turning boiler switch off? thanks!
The burner seal being porous is to make sure it’s safe from fumes
I believe this should be it so have ordered with a blanking plate. Hopefully once this is it the Hive system will get the boiler going by itself. Can't wait to try it. Thanks for your help again!
