Insulating wide valley
bsr
5 Aug 2008
Gloucestershire
Hello
See the attached picture. I have a wide lead valley (blue) running the width of my house where two pitched roofs join. The valley is about 400mm wide.
I have insulated the rest of the roof space with 300mm mineral wool. What should I do here? Can I fill with mineral wool up to the plywood deck (red), or do I need to leave a space for ventilation? Should I use an alternative product? Normally I would leave spaces at the eaves to allow cross-ventilation, but there is none here since there is a pitched roof on both sides.
bsr
Condensation is likely to form n the under side of the lead. Slip some pir board under with no gaps
Noseall, I'm not sure what you mean. The valley is very close to the rooms. At the moment I have only plasterboard, 300mm air space and then the valley. That's why I want to insulate it, but without causing any damp problems.
