Why bring neutral to switch?
  • Thread starter Thread starter bsr
  • Start date Start date
bsr
5 Aug 2008
Gloucestershire
Hello
I hired an electrician to alter wiring for my new kitchen. My house uses a normal lighting radial looped in at ceiling roses.
We added new plinth lights, switched separately from the ceiling light but in the same box using a 2G switch. Instead of extending the radial into the new light, he took a perm live and neutral from the existing ceiling rose to the switch. The perm live was daisy chained into the common of both switches and the lights were single pole switched as normal. The neutral came into the box, was joined in a choc block, and then went out again in a 3C+E to the new lights.
Could you explain why you would do this rather than extending the radial? I didn't ask him because I didn't see it until he had left (and I had paid him).
bsr
You say plinth lights, so doing it the way you think would require a cable from ceiling rose to plinths and then, presumably, back up to switches - instead of just rose to switch and on down to plinths. He has extended the radial.
I am assuming your plinths are not in the ceiling.
He's done you a favour whatever- if you ever want to put some tarty control system on those lights you'll be able to. Plus running neutral with live as he's done reduces EMI (which can interfere with hearing aids among other things).
... Plus running neutral with live as he's done reduces EMI (which can interfere with hearing aids among other things).
I'm not sure that I get that. Provided that all cables have two cores with the same current flowing (in opposite directions) in both of them (as, for example, with a drop from rose to a switch), things will be as balanced as they could be from the EMI point-of-view, even if no neutral is involved, won't they?
OK thanks, so there are two possible reasons:
  1. To provide a power supply for a smart dimmer (it's not, it's a V-pro, but this provides future proofing)
  2. Because if he had wired a normal "loop in" in the ceiling using a junction box, he would have to take the live from the ceiling loop in, to the switch, then back up to the ceiling, then down to the floor again (so probably more wiring / hassle overall)
Thanks!
