A differential scope probe would be the first step...before damage is done.
Battery-operated test equipment gets my vote!
Sorry what do you mean "using software on the Arduino to convert the voltage levels" as far as I can see the resistors are dropping the voltage and the Arduino is just processing the signals or have I misunderstood?
Hence the removal of the need to observe polarity in some boiler / heating systems ? ?.
Loss of communication could create a hazard if the system is not designed / programmed to fail safe in the event of an un-expected loss of communication.
The thing you originally posted, and linked again by picasso, using software on the Arduino to covert the voltage levels, is ghastly; please don’t use that.
Hardly, the boiler is designed to work safely without any further input, without even the ebus at all.
just a virtual ground as a reference,
The "reference" is the negative pole of the E-Bus pair.
There are 5 states on the E-Bus pair determined by the voltage between the two wires of the bus,
Less than 9 = bus de-powered
between 9 and 12 = logical 0
between 12 and 15 = invalid **
beween 15 and 24 = logical 1
greater than 24 = fault
** the duration of the invalid state can be used to determine the "quality" of the bus system.
You have obviously misunderstood.
The voltage levels as input are decided by the potential divider formed by the 47K and 10K dividing the input by around 1/5th 22v/5 = 4.4v as the input to the Arduino providing one of the digital states.
The software provides the timing and conversion to one and zeros, which can then be read by another system via the USB.
Well it’s either that or oven bake....fry the chip.
