- Joined
- 15 Feb 2019
- Messages
- 13
- Reaction score
- 0
- Country
Hi there,
I am attempting to replace my Honeywell CM707 thermostats with Hive Single channel receivers and thermostats. It is a new build property with a Logic System s24 boiler. There are CM707 thermostats up and down (2 zone) which control only heating. Near the boiler in the garage is a Honeywell ST9100C which I believe controls the entire system. On the cylinder in the airing cupboard is an ESi dual cyclinder thermostat which controls the call for hot water.
There are only 2 wires coming to the CM707 faceplates, a Live and Neutral which are attached to the B & A terminals respectively. When I attach these to the permanent live and neutral terminals on the Hive faceplate, it powers up the receiver but manually turning on central heating does nothing other than light up the green light. The boiler doesn't fire up.
What am I doing wrong?
