- Joined
- 27 Jan 2008
- Messages
- 27,680
- Reaction score
- 3,352
- Location
- Country
I know British Gas confirmed that “remote disconnection” is possible but that smart meters grant no additional powers to disconnect than with standard meters. A spokesman for the energy giant said they would never disconnect a customer without an engineer visiting the property.
However the question then is why fit them? I will guess because same meters are used in France where their tariff limits maximum power, so you pay less for a 30A supply than for a 60A supply.
We are told they are very secure, however in USA there have been court cases where some one has been sacked and then disrupted the system. As to how it is turned off we don't know, can some one mistake an address? So turn off supply to 1 Llewelyn street Shotton instead of 1 Llewelyn street Bryn-y-baal, or 10 castle street instead of 10A?
I am not worried about being turned off for non payment or a house fire, however if the fire brigade can request a disconnection or any other emergency service like police then there is a possibility of error, and if not, why have the ability?
Years ago I had a tool from Scottish Power that clipped on the supply lead, this gave me an approximate reading of power used (no power factor correction) and told the supplier what I had used, so the estimated bill was within a few pounds of what was actually used, once a year or so this was corrected with an actual reading. It was no more that £5 out, which is to my mind good enough, when compared to this old system, the only advantage of the smart meter is the remote disconnection function.
When I had the Scottish Power unit, I started to monitor power use, however it was really useless as not a clue which circuit was using the power, was it the freezer or fridge not a clue. Now the plug in power meter helps, you can see faults, when for example the freezer never switches off, but for whole supply that is rather useless.
