As the window frame is completely sealed both on the outer and inner skin (if fitted correctly), why are we closing the cavity with extra materials? Isn't the window frame good enough?
while I backed the van upto the house
The cavity will show on the internal reveal.As the window frame is completely sealed both on the outer and inner skin (if fitted correctly), why are we closing the cavity with extra materials? Isn't the window frame good enough?
You mean you had to ram the windows with the van to get them in, they were that tight![]()
Jeez, you have nosey neighbours.The window frame isn’t as wide as the cavity.
I measured 1 window exactly and it didn’t fit. Best thing was we posted it out through the upstairs opening to pull it back into the opening.
I had the get the missus and kids to hold it while I backed the van upto the house, then I trimmed the fins off the sides to make it fit.
I rent a room to 34 illegals
I fitted our DG 30 years ago myself, with some help. When they all needed replacing around 5 years ago, I looked at doing them myself, but pricing supply on up versus supply and fitting, it seemed not worth while.
30 years ago we were all a lot younger,fitter but poorer, its nice when you get to the stage where you just can hand over the money and get the job sorted in a few daysI fitted our DG 30 years ago myself, with some help. When they all needed replacing around 5 years ago, I looked at doing them myself, but pricing supply on up versus supply and fitting, it seemed not worth while.
