Why can't I buy what I want?
20 Aug 2009
Dorset
Manufacturers really need to improve their product range.
How come large companies like MK and Crabtree don't make flush converter sockets after all this time?
Why don't they make cooker panels in the vertical plane? (You can get Contactum ones if you're lucky.)
Doorbells with built-in transformers (technical specification kept top secret) that don't have their secondary voltage matching products such as Ring bell pushes.
Cleats that fit armoured cable??
30amp connector block - what's happening to that - it seems either too big or too small for it's intended use.
Junction boxes with terminals that snap the conductors before you even finish tightening them.
Earth clamps where the terminal screw head bends out of shape.
Grommet strip that is too small to stay on to anything.
I could go on.
They have to fit a one gang back box and the plug pins would hit the existing plaster at the side of the back box.
Perhaps there is little demand.
Perhaps Ring should have designed their pushes to match the voltage that has been standard for many decades.
[/QUOTE]
I could go on.
I'm glad you didn't
I don't follow, if Robus can make a converter, why can't MK or Crabtree make their version?
I'm not expecting slimline, just to look remotely similar.
As BAS has said, there obviously has to be somewhere for the plug pins to go, no matter who makes it!
A quick look found one Robus one calling itself 'flush' - but it's actually 20mm deep - which I would hardly call 'flush'.
It's not BAS, it's the other one.
I have no problem with Robus, and their converter sockets. I fully understand how they work. I have no problems at all with any of this.
ALL I am trying to say is this; Why can't MK or Crabtree make their OWN version of a converter socket?
The REASON for this IS - say I have a house all wired up in the current range of Crabtee stuff. Then lo and behold, I need to change a single socket to a double. Don't want to chase out the box. I'll fit a converter socket. If I get a Crabtree one, it will look better against all my other other Crabtree stuff. Oh bugger - Crabtree don't make them. Well Robus do one - hardly goes with my existing Crabtree range - but there you go.
Whoops, so it is! (I tend to think of the pair of them 'in the same breath'!) :oops:
I have no problem with Robus, and their converter sockets. I fully understand how they work. I have no problems at all with any of this. ALL I am trying to say is this; Why can't MK or Crabtree make their OWN version of a converter socket?
As has been suggested, I suspect that it's probably a matter of (lack of) demand.
I suppose it's a personal thing - it might 'look better' in some senses, but it would still stick out almost as much as a surface-mounted socket.
Is there any chance that you could coax a Crabtree double socket into a 16mm Double surface box? If you could, it probably would not 'stick out' any/appreciably more than a Robus converter socket.
I had no idea that you'd concocted such a bizarre, fantastical version of reality to use in your head as an alternative to the actual one.
How about a 2G socket with 2 sets of separate terminals, to be used when wanting to extend a ring, and with some magic feature to stop numpties from using it to break a ring?
I use 2 x LAP 13A 1-Gang Unswitched Grid Modules White and a LAP 2-Gang Front Plate with 4 Module Aperture OK you can wire them wrong, can't stop that, but it does allow one to split a ring and extend.
