Planning to heat a new-build 18sq m extension with wet UFH but without resorting to an off-the-shelf kit. I have several reasons for not wanting to buy a kit - I think they're generally over-priced for what they contain (I've seen standard looking £60 CH pumps thrown in with a couple of isolators and a mixer maybe worth £25 sell for over £300). Also I don't want all the kit components (for instance I have my own custom control electronics already integrated with the rest of our CH system that monitors and controls as many zones as I like).
Two questions then arise: can the barrier pipe for the underfloor loop just be regular PEX such as a 100m of 15mm SPEEDFIT PE-X BARRIER PIPE (it's never clear to me if the kits supply something subtly different/special or not) - and where to get an automatic valve that mixes a variable amount of return with feed to reduce the loop temperature from somewhere around 70C from the boiler to 30C or so for the floor. For example, I've already used some £25 automatic mixers for separate hot & cold taps in our bathrooms to prevent scalding (fantastic bits of kit) and I don't really see why such a valve wouldn't work here.
Given that I've priced all this up at around the £250 mark compared with kits in the region of £500 I think it's worth investigating. Please shoot me down if you disagree!
