Getting a sparky to install an inline fan for our ensuite, given it's next to the bed we want either a pull switch only arrangement or a timer but with a pull switch we can use to switch off at night. No RCD on light circuit. Isolator apparently has to go in loft. Now I expected the pull switch to be on the live feed to achieve what we want. But I was told that if the switch was on and the light triggered the timer, it would run on for the time even if we pulled the cord after . I suggested a double pole switch but apparently that would be rather bulky and 45amp. Now he's found a new pull cord triple pole isolator which I guess is fine, but apparently we still need an isolator in the loft to comply with regs
Make sense?
Additionally,we recently had the main bathroom refurbished and the guys put an axial fan in the ceiling, which the new guy says he can't do because of regs and no RCD. The guys got a subbie to install the axial, isolator in loft and triggered by light or humidistat.
Make sense?
