I'm trying to find a T bolt or nut that will fit into this track. All the ones I can see have the wrong shape, or are slightly too thick. I found some thin headed ones but they are too wide for the slot.
For background, I won't be suspending this fixture, It'll be stood on end, portable, battery powered from a Makita 18V pack, and filled with 624 addressable RGB LEDs and used to provide effect lighting for a band. There'll be 4 or 5 of them.
I'd like to attach the fixture to a tripod using the T-Slot and a lighting clamp arrangement. But 1st I need a T bolt. Ideally I don't want to drill through to the inside and bolt it that way, as I like the flexibility of the T-slot.
External Groove width - 6mm (An M6 bolt will fit and slide into the groove)
Internal Groove width -10mm
Groove depth - 3mm (narrowest) to 4mm (widest)
Photos below.
Cheers.
Photos below.
Cheers.
