Indirect unvented and secondary return pump
just use a relay with a timer they are not expensive, low voltage from the PIR will switch the 240V supply on from the relay to the pump, I would be using a different electrician if he cant work that out, @Dan Robinson loves these things , I have tagged him for you he has a lot of experience doing this
Thanks again! Using a different electrician would be tricky and he’s been good so far, we just want to help him acquire a solution! It’s not the wiring the pir to the pump that’s the problem, it’s how we prevent activation of the 2nd pir sensor (we have 2 bathrooms upstairs) from turning off the pump, if it has been turned on beforehand by the 1st pir sensor. This situation could occur if both bathrooms are being used around the same time. Dan did indeed install our heating system, hopefully he can help!
Each pir wired to a time delay relay set to say 15 minutes should overcome this
Or a simple time clock set to an hour in the morning and 3 hours in the evening.
There's always the risk of over thinking a problem ;)
I thought I had already said that :LOL::LOL::LOL::LOL:
Oh so I called it a timer instead of a time delay, please forgive me :rolleyes::rolleyes::rolleyes::rolleyes::rolleyes:
Seriously OP @Dan Robinson is the best to sort this for you he knows the system and he is great with controls, we are just having a bit of banter, he knows what he is doing , I would use him rather than your electrician
Cheeky :p... Not a regular situation this one. I only did the cylinder, boiler and controls. All other plumbing and whatnot is done by others - and done well.
Do I really have to drive down and pull you out of a hole on this one :LOL::LOL::LOL:
I know the answer mate but I am scottish, but if you want help just ask :LOL::LOL::LOL: seriously pal we can help each other out, I respect your posts and you know what you are talking about, which is why I recommended you, doesnt mean that us lesser mortals dont have an input
Ian and Dan, thank you gentlemen, you've been really accommodating for which we're very grateful and we hope a solution has been found! We'll speak to our electrician tomorrow and will let you know how we get on.
