- Joined
- 28 Apr 2004
- Messages
- 8,381
- Reaction score
- 987
- Country
Maybe I'll try a quick squirt of the specialist WD40That may be so, but the product they make called WD40 is a water displacement liquid not a contact cleaner.
What does that say?
Yes, in a more general sense, I can understand that, but ....Well it's only contrived to unambiguously define the structure of the molecule. in this simple example the propane bit simply means that there are at most 3 carbon atoms in a row (it's not really like that, but that's a whole different kettle of fish) the dimethyl bit means there are 2 methyl groups (CH3) attached to the propane "backbone" and the 2,2 bit means they both come off the second carbon of the propane backbone.
Indeed, but I obviously was talking about 'this case', in which, as you say, it is unambiguous - as I presume it would also be in any case in which all the hydrogens of the hydrocarbon backbone had been substituted - for example (assuming that it exists!) ...Using "your" nomenclature for C5H12 tetramethylmethane, is ok in this case as it is unambiguous however for longer chain hydrocarbons it would run into ambiguity problems, as you couldn't determine which groups were attached to which carbons.
Fair enough - I got pretty close (and, I think, 'unambiguously', even if my offering probably had some redundant numbers in it!)2,3 tetramethylbutane.
Going back to the original issue, I suppose my thinking went a bit further than just nomenclature ... I don't know what, if anything, it means in terms of properties, but I "think of" the molecule as being 'methane with all four hydrogens substituted by methyl groups' (hence my "tetramethylymethane"), rather than as 'propane with the two single hydrogens substituted by methyl groups' (as per your "2,2-dimethylpropane").
Isn't that what I suggested in the first place?2,3 tetramethylbutane.Hmm, not quite technically correct, but not a bad stab, it's 2,2,3,3 tetramethylbutane, which on reflection make sense.
JohnW2 said:... which I suppose I might call "hexamethylethane" - and which I imagine you would call something like 2,2,3,3-tetramethylbutane?
To be fair, that in itself was no great surprise, given that, in general (and for whatever reason), the "R" forms of molecules tend to have much less (if any) biological/pharmacological effects than do the corresponding "L" forms - and that includes unwanted effects.Well it's true that a molecules structure can have massive implications, sad case to demonstrate is that of Thalidomide (don't ask to give me it's IUPAC name!) not isomers, but racemes, but the "R" form of it does exactly what is says on the tin, the "L" form causes terrible birth defects.
Isn't that what I suggested in the first place?......
I agree. As I wrote ....Yes, you did, but I confess I don't really know why 2,2,3,3 offers any more disambiguation than simple 2,3 hey ho!
Fair enough - I got pretty close (and, I think, 'unambiguously', even if my offering probably had some redundant numbers in it!)![]()
Hmmm - as I think we have agreed, there is no ambiguity in either of the 'descriptors' of that molecule, but I think that's more than can be said of some things in BS7671!Well, it's seems both are fine, seems chemical nomenclature is about as good as electrical "standards" !
