SALL2009, good evening again.
In no particular order.
Look at fitting a room vent into the blocked of chimney in the ground floor, provided the chimney stack checks out OK? and ensure there is a vented terminal on the pot.
As for the "dampness" between the wall paper and the plaster above the area of wet plaster on the ground floor? If it were me, I would strip the paper and wait, what can and does happen is that the dampness from lower levels, provided there is enough of it will "wick up" the interface of plaster and wall paper to cause damp marks to appear on the plaster, in a load of cases leave the wall paper of and allow the plaster to breath and dry.
The possibility of failed Cavity Retro-filled insulation, a whole different can of worms? I recall asking that question several reply's back?
At times what can happen is that the fill becomes saturated, the water gathers at the base of the wall? but in your case the presence of an un-vented chimney ??
As above, I would tend to play the waiting game, to see if the dampness dissapears as the property warms up or ??
As for how to proceed if indeed the cavity fill has failed?
A/. Find out who holds the insurance backed guarantee for this material, the vendors Solicitor [Lawyer] may have some info?
B/. Get the property surveyed for failed cavity fill, there is a vociferous small "industry" around this form of defect.
Ken.
Ken.
