Diamond core drill bit with SDS drill bouncing off the brick work
Core drill follows the angle you start with regardless of any pilot hole.Thats why it comes with a centring bit .
I suspect that we might be at cross purposes here.
I am referring to the core bits with a central (blunt) pin/rod that extends beyond the diamond tips. With those, you obviously need to drill a hole the same size as the central pin/rod. If you don't pre-drill the core ain't gonna go anywhere.
Are you referring to the smaller diamond core bits used to go through tiles rather than walls?
Every core bit I used up to 110mm is mounted on stem with 7mm masonry bit which keeps the main bit centred .
Ok. That makes sense now.
So does that mean that you have to use them with the hammer action on?
I think we've established that you've drilled the pilot hole through and that's not stopping the main core going in?
My drill is 1300 watts and is a proper core drill (geared to the correct speed) but still struggles with a 127mm core on my hard Accrington bricks. As previously advised, start the cut at a slight angle and even a gentle waggle so it's not trying to cut the entire circle at the same time. If all else fails chain drill round the circle with a small (5mm) bit first.
And watch the drill for overheating - when it starts to get hot pull it out and just run it for a minute so the fan cools the motor.
Before I got the proper drill I managed a few 127mm cores with my 18v DeWalt - but very slow going and ate the batteries (but shows how good modern cordless are). I'd also used an sds (on drill, not hammer setting) but I think the speeds are wrong for diamond cores.
You are lucky that you didn't have a snatch - no SDS drill I've ever come across is rated more than about 80mm on the clutch, and many are either less or have no clutch at all. That's more of a safety issue to my mind.
Accrington brick! rather you than me mate:eek:
I have to say that for those we simply get the hole drilling man in - and he uses a water-cooled set-up for engineering grade concrete and engineering brick......
Accrington bricks, hmmm, our house is made of them, they are hard as hell, not sure which is harder, Nori's or Staffy blues?
