Soft closers for internal doors?
6 Sep 2008
the pan drawers in the kitchen are soft close self close thanks to a mechanism that looks like this:
https://www.screwfix.com/p/hafele-soft-close-mechanism-for-roller-runners/3181J
A plastic bogey travels along an L shaped slot as the drawer is pulled open then flicks out of the way as the end of the L is reached. When closing the bogey flicks back, captures the activating finger tab and travels back to the closed position using a spring-damper arrangement that means the drawer self closes softly when it reaches circa 4 inches open
I'm wondering if a similar thing exists for internal doors? Something that will catch and close in the last few inches of ajar, but isn't one of those big, ugly overhead force closers/jamb based chain closers that pull closed all the time - I'd like to be able to leave doors open and only have them activate a self close when nearly closed. I'd prefer something cheap (like that drawer runner) and easy to hide
You can get kitchen door piston style closes that only act on the last 20mm of closing , for large kitchen doors 2.2m Use two or three but there are some with varying weight capacities .
I have been thinking to look into something like that, to stop SWMBO from slamming kitchen drawers shut. The original drawers were just plastic sided/ hardboard base and they soon fell apart with the weight and abuse. I replaced the drawers with steel sided, ply bottomed ones which included new side runners. These have stood the test of time well. The runners have a final slope, so the drawer is pulled closed for the last 1/2"
How would these Hafele runners fit in with the above?
do you mean kitchen doors or room dividing doors?? Kitchen cabinet doors, Blum do a range of soft closers.
Kitchen cabinet doors are already soft close
I mean for the doors that divide rooms. My pull out larder probably weighs the same as my internal room door, and the larder has a soft close self close similar to the drawer closer
Perhaps though trying to do it in one mechanism is trickier than eg having self close hinges with a flat part so a door can stay ajar, and a piston soft close in the jamb
Make sure you get the right mechanism; some of these things are only for metal drawers, others only for wooden ones. Might be simplest to replace your runners with soft closing ones
https://www.eurofitdirect.co.uk/products/ball-bearing-45kg-soft-close-drawer-slide-46x400mm-ext-100
But to use the Screwfix ones is just a question of alignment; they come with fitting instructions and I describe how they work in the original post. Buy one and have a play with it, it should become apparent pretty quickly how they work. The critical part is a plastic finger that pulls the mechanism open, attached to the drawer, while the mechanism itself is attached to the cabinet
Some are , by no means all and they use a variety of methods, some have soft close hinges , older style use a separate piston to damp the self closing action of the hinge .
