    Dismiss Notice
Soft closers for internal doors?
Discussion in 'Wood / Woodwork / Carpentry' started by cjard, 6 Apr 2019.
  1. cjard
    cjard
    6 Sep 2008
    2,334
    Thanks Received:
    250
    Country:
    the pan drawers in the kitchen are soft close self close thanks to a mechanism that looks like this:
    https://www.screwfix.com/p/hafele-soft-close-mechanism-for-roller-runners/3181J
    A plastic bogey travels along an L shaped slot as the drawer is pulled open then flicks out of the way as the end of the L is reached. When closing the bogey flicks back, captures the activating finger tab and travels back to the closed position using a spring-damper arrangement that means the drawer self closes softly when it reaches circa 4 inches open
    I'm wondering if a similar thing exists for internal doors? Something that will catch and close in the last few inches of ajar, but isn't one of those big, ugly overhead force closers/jamb based chain closers that pull closed all the time - I'd like to be able to leave doors open and only have them activate a self close when nearly closed. I'd prefer something cheap (like that drawer runner) and easy to hide
  2. EddieM
    EddieM
    15 Feb 2009
    6,779
    Thanks Received:
    253
    Country:
    Perko make a range, aint cheap though.
  3. foxhole
    foxhole
    14 Mar 2006
    14,070
    Thanks Received:
    1,509
    Kent
    Country:
    You can get kitchen door piston style closes that only act on the last 20mm of closing , for large kitchen doors 2.2m Use two or three but there are some with varying weight capacities .
  4. Harry Bloomfield
    Harry Bloomfield
    30 Dec 2018
    1,572
    Thanks Received:
    162
    Country:
    I have been thinking to look into something like that, to stop SWMBO from slamming kitchen drawers shut. The original drawers were just plastic sided/ hardboard base and they soon fell apart with the weight and abuse. I replaced the drawers with steel sided, ply bottomed ones which included new side runners. These have stood the test of time well. The runners have a final slope, so the drawer is pulled closed for the last 1/2"
    How would these Hafele runners fit in with the above?
  5. EddieM
    EddieM
    15 Feb 2009
    6,779
    Thanks Received:
    253
    Country:
    do you mean kitchen doors or room dividing doors?? Kitchen cabinet doors, Blum do a range of soft closers.
  6. opps
    opps
    16 Jun 2006
    3,583
    Thanks Received:
    492
    London
    Country:
  7. cjard
    cjard
    6 Sep 2008
    2,334
    Thanks Received:
    250
    Country:
    Kitchen cabinet doors are already soft close
    I mean for the doors that divide rooms. My pull out larder probably weighs the same as my internal room door, and the larder has a soft close self close similar to the drawer closer
    Perhaps though trying to do it in one mechanism is trickier than eg having self close hinges with a flat part so a door can stay ajar, and a piston soft close in the jamb
  8. cjard
    cjard
    6 Sep 2008
    2,334
    Thanks Received:
    250
    Country:
  9. cjard
    cjard
    6 Sep 2008
    2,334
    Thanks Received:
    250
    Country:
    Make sure you get the right mechanism; some of these things are only for metal drawers, others only for wooden ones. Might be simplest to replace your runners with soft closing ones
    https://www.eurofitdirect.co.uk/products/ball-bearing-45kg-soft-close-drawer-slide-46x400mm-ext-100
    But to use the screwfix ones is just a question of alignment; they come with fitting instructions and I describe how they work in the original post. Buy one and have a play with it, it should become apparent pretty quickly how they work. The critical part is a plastic finger that pulls the mechanism open, attached to the drawer, while the mechanism itself is attached to the cabinet
    • Thanks Thanks x 1
  10. magicmushroom666
    magicmushroom666
    11 Jan 2010
    221
    Thanks Received:
    36
    Essex
    Country:
  11. foxhole
    foxhole
    14 Mar 2006
    14,070
    Thanks Received:
    1,509
    Kent
    Country:
Loading...
Share This Page
