- Joined
- 25 Apr 2019
- Messages
- 4
- Reaction score
- 0
- Country
Hi guys, the boilers pressure is going up then lockout when HW runing ,CH is the same, it will go back on and same thing happened again.
so have the heat exchange plate changed, and E Vessel refilled to 1.5bar ,no improve, the driveter valve motor seems working fine.
I am not sure if this is cause by the water pump, ive open the sliver cap in the middle and turn on HW or CH, the boiler start to run but the motor is not spinning(pump motor itself is working,i took it off and tested it), the boiler make noise like there is not enough water circulation going up the main heat exchange then lockout, could it be the problems from the pcb board???or some sensors relate to this ??thanks for reading guys , please help me out
