I have just bought these steel rod balustrades to replace the existing wooden one but they seem massive as you can see. They were relatively cheap at under £200 to do the whole stairs compared to the usual cost which run into hundreds if not thousands.
They are 106 cm high compared gto the existing one of 83cm and the usual height of about 90- 95cm. Rather than spend hundreds buying replacement could the posts be cut and welded to take a few cm out and how much do you reckon it would cost per post ?
