Ok, we had an unvented cylinder fitted last year and every now and then our en suite would fill up with bad smells. We located this to the pipe that comes out of the unvented cylinder which has a tundish on it. The problem here is that this pipe drains into the sink waste. As a result sewer smells are penetrating the room. The smells go away if cap this pipe off but this is not safe of course, however neither is sewer stink !!
Has the plumber cocked up here ? does this pipe need some kind of valve on it ? or does it need to be disconnected from the sink waste and fed directly outside ?
Cheers.
Cheers.
