Hi I'm so bad at DIY and need to fix a curtain pole bracket. It looks as though the previous owner used some kind of hollow wall fixing which have come away pretty easily.
The problem that I have is now there are two 10mm wide holes and am wondering what fixing to use to secure? The hole feel pretty deep (50-80mm deep) with no obvious void the other side of the plasterboard before hitting what feels like block.
Should I try to get a small toggle in the small void? Or should I try to drill further and get a plug deeper into the block?
Thanks in advance
Thanks in advance
