I was right.I'm sure some ******* will be along soon to say that no deal/WTO will be fine, desirable even.
Less so when the penny drops that because the state pension is essentially a giant Ponzi scheme, the more the young sink into unemployment and poverty the less money there is to pay it.Since Quitters are predominantly over retirement age, they look with fortitude at younger people sinking into unemployment and poverty.
I haven't looked at the demographic distribution of older people, and compared it with the percentage of older Leave voters, and then done a subsequent calculation.Isn't that like saying "remainers are likely to be young people" which apparently is not so?
It is far from unheard of for countries to cut pensions for existing pensioners. It could just as easily happen here.
So ... at a guess, it could well be not true, then.But at a guess, it could well be true that Leavers are predominantly/likely to be older people. (over retirement age, I'm not so sure),
Unless there were not enough of them.simply because (conversely than with the young people) there are more older people than young, and the older people did vote (or were more likely to vote), and they were more likely to vote Leave.
Except the rabid Brexiteers who will probably soon be in charge of the Tory party....
Not just pensions...It is far from unheard of for countries to cut pensions for existing pensioners. It could just as easily happen here.
Of course. If it could be true, it could (though not as likely) be not true.So ... at a guess, it could well be not true, then.
Well, you could add an "unless" to the statement that" Remainers are likely to be young people" unless there were more older people who were also Remainers. But that then changes the assertive sentence to a conditional sentence.Unless there were not enough of them.
Notch made no attempt to prove his point when he was challenged on it.Isn't it normally the case that the maker of sweeping statements should prove it?
Why? He is doing exactly what Notch did, and not attempting to prove his point.I take his lack of response to be indicative
I didn't particularly enjoy it.You apparently liked doing the calculations against Notch.
The same as John, then.Notch made no attempt to prove his point when he was challenged on it.
That is John's MO; when proved wrong, he just ignores it.Why? He is doing exactly what Notch did, and not attempting to prove his point.
It looked like you did.I didn't particularly enjoy it.
Ok, then - figures from quick searches.But as Notch was denying the absolute obvious, needs must.
They are both the same on that score then.The same as John, then.
How can you tell?It looked like you did.
What about the overseas voters? Edit: No matter, only 264,000.Ok, then - figures from quick searches.
population - 66,000,000
over 65, 18% - 11,880,000
turnout of over 65s, 90% - 10,692,000
voted leave, 61% - 6,522,120.
Less than 50% of the leave vote.
