Had a new Worcester Bosch Greenstar 37 fitted just over 9 years ago, brilliant boiler, never a problem. Then two weeks ago, no hot water. Up into loft to find boiler dead. No lights, nothing. Nada. Called out the Plumbing/Heating firm that fitted it/did the re-plumb of the house, who took the front off, had a look & a fiddle and found the isolation switch next to the boiler had burnt out due to "a standard 13a fuse being left in the switch when fitted, instead of being changed for a 3a fuse..." (we had the whole place rewired at same time as new boiler) - so he advised me to fit a new isolation switch & 3a fuse which I did. The boiler now started up and worked as before.
Then a few days later, no hot water. Odd. Up into loft to see a flashing 'EA' in the digital panel. I did the 3-second reset, did the trick, all was fine again. Since then, it's been doing this every few days. 'EA' seems to flash ON for longer than it's off, with the alternating blue light, if that makes a difference?
So I wonder if anyone might be able to give me a pointer as to what is going on? Rest assured I am NOT going to get involved if it's anything more than a push-button fix that I can easily do. I just want to know if this is a known issue before I spend more money for a callout charge/service fee!
Thanks in advance - hoping someone can offer some advice!
