- Joined
- 5 Nov 2010
- Messages
- 409
- Reaction score
- 3
- Country
I've noticed the floors and walls are not level on the first floor. Now I know walls are rarely straight but by just how much are you supposed to allow before you start thinking it's not normal?
The semi-detached house was (I think) built in the 1950s and I can't see any cracks on the outside.
I built a sliding wardrobe not too long and noticed the floor was about 2.5cm lower than the other side, so I really had to adjust the doors quite a bit.
Now, I've assembled a bookcase on the other side of the house and realised by using a spirit level that the shelves are not level and the top of the bookcase is about 2cm away from the wall.
It's the floor I worry about more. The bookcase is 80cm wide and I reckon you need to raise one side about 1cm to make it level.
Does this sound typical to you?
With the bookcase, what are you supposed to do in situations like this? Add something under the bookcase to make level the width and depth? If I secure the top of the bookcase to the wall (which you should do) then it will put a strain on the bookcase itself as it's pushed back a bit.
Should I get an expert in?
Thanks very much.
Thanks very much.
