DIY upgrade British Gas Smart Linked Thermostat to Hive?
5 Apr 2011
Surrey
Has anyone done a DIY upgrade of an old British Gas Smart Linked Thermostat to a Hive receiver?
Do the two receivers require exactly the same cabling? Is it simply a question of removing the BG receiver, replacing it with the Hive receiver and reconnecting the same cables?
Even better, are the backplates of the two receivers compatible - i.e. do you simply need to remove the front part of the BG receiver and replace it with the Hive receiver?
The back plate and wiring are the same. All you need to do is change the receivers over.
Just to confirm: my existing BG Smart Thermostat receiver has the following connections:
- Permanent Neutral
- Permanent Live
- C (on terminal 1)
- CALL (on terminal 3)
Would C correspond to "Common" and "CALL" correspond to "Heating on" on the Hive single channel receiver?
- Permanent Neutral
- Permanent Live
- C (on terminal 1)
yes
