I've got a hot water cylinder and a secondary circulation pump to make sure the water is warm at the taps. At the moment it's just on a mechanical timer, meaning that it's pumping way more than it needs to and more heat than necessary is being lost through the pipes.
I've been advised to put a pipe stat on the return pipe to cut off the pump when the return gets warm.
Two questions:
1) Is this the best configuration to strike the balance between instant warm water at the taps and energy efficiency?
2) Do I need a high limit pipestat or a low limit?
Thanks.
Two questions:
Thanks.
