- Joined
- 27 Jan 2008
- Messages
- 28,643
- Reaction score
- 3,492
- Location
- Country
The TRV heads report to PC current temperature of each room, and also the target temperature, so theory if current is below target then I want boiler to run, the socket runs the pump for main house, so at moment the socket is timed to turn on at same time as programmer, there is no room thermostat in main house.
The granny flat has a thermostat, which turns on a different pump, but seems strange to have thermostat in the kitchen, there is no thermostat for domestic hot water.
So job one is swap all TRV's for new, as the wifi heads will not fit old TRV's I have 4 MiHome Energenie wifi heads which will go in main rooms, so office, living room and craft room, however I was going to fit the cheaper Terrier i30 heads in other rooms, as main idea is they stop over heating rather than ensuring hot enough, so can switch off rooms at times when not used.
Considering a Nest e for granny flat so we can remotely switch it on when expecting visitors.
However although I have the requirement as to if boiler/pump is required reported to PC, I can't see how to use the info to switch on the pair of sockets to control boiler/pump.
As far as I can work out I need to use IFTTT (if this then that) but as to how is another question.
Alternative method would be three programmable thermostats in parallel, so if any of three main rooms under temperature then the boiler runs, however three wifi thermostats rather expensive, so looking at hard wiring three thermostats. That may be the best method, however seems daft to require two thermostats per room, if we have a thermostat on the TRV why should I need a second in the same room?
