- Joined
- 27 Jan 2008
- Messages
- 29,647
- Reaction score
- 3,668
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
My late mother at 93 needed careful central heating control, I tried all sorts over around 4 years when she was under my care to improve the control.
Fitted two thermostats one in each room used with programmer and programmable thermostat so it swapped between the two day and night, the wireless programmable thermostat lost sensitivity and had to be moved closer and closer to receiver ending up in kitchen one meter away.
Next was a pair of wifi TRV heads again one in each room, main thermostat put back in hall.
Then fitted a standard TRV in hall as well as thermostat on wall at this reasonable control.
So mother has died and looking to rent house, not wanting to have to maintain the internet controlled TRV heads these were removed and replaced with the old manual heads, I expected the room temperature to go daft again.
However noticed no change, it would seem now there is a TRV in the hall all works A1, did not need the expensive electronic valves, yet we are told do not fit a TRV in the room with the wall thermostat, however in practice it has shown in real terms it works.
