Greetings from Canada!
Hot water has been a pain for the last 2 weeks, started as hot water will turn cold mid-shower but will recover. Has been getting worse with hot water cycling 3x in about 10 minutes. I took a shower today and hot water was good for about 2 minutes and it turned cold, I had to cycle the shower faucet on/off to recover and will turn cold again. I can manage but the girls are not happy. I'm expecting to totally have no hot water in the next day or so. No fault codes.
I called a tech but he isn't familiar with this boiler. I cleaned the NTC sensor the other day but it didn't help.
Today, I found a video on how to test the hall effect sensor with a magnet. The only magnet I could find is from a screwdriver and it didn't light up (maybe magnet too weak). I'll get a stronger magnet from my toolbox at work and hopefully will confirm fault.
For the meantime, can someone provide me the voltages for the NTC sensor and the hall effect sensor? Is there a proper wiring diagram I can get (not the one form the cover)? I will try to troubleshoot some more tomorrow.
Thanks!
Thanks!
