Baxi main calling for heat fault
if it has three terminals it will work , you just need to work out which coloured wire goes to which terminal, if it is an approved part it will come with a wiring diagram
Checked with the seller the part does indicate which wire goes where will also replace the diaphragm as the boiler is getting on a bit
Will let you know how i get on
make sure that you cover the PCB housing with cling film or a poly bag and a towel, as any water leaking when changing the diaphragm will go straight in there and fry the PCB
Sure will do, is there likely to be a lot of water? Or a trickle?
isolate the cold inlet and open the lowest hot tap and you should be fine, there will always be some that comes out every system is different, nothing to worry about just protect the electronics they dont like water
Nice one! Thanks alot :)
All sorted! The button on the microswitch looks like it had failed.
Replaced the diverter valve as good practice, although the original one looked fine.
Many thanks for your guidance! :)
Got a problem, there is a slight leak coming from the rear of the diverter valve, the bottom screw is tight but it appears to be coming from the hole in the middle, I thought maybe a screw got loose, but it doesn't look threaded
Any ideas?
Removed the complete brass diverter assembly, fitted the small O ring at the back of the rear spindle, although there wasn't one fiited, all seems well now...
