I just poke a fine screwdriver thru till I hit one then measure on from that.
Are studs in all walls and 400 centres?
No, much more likely to be 600. Plasterboard is usually 1220mm, so 610mm centres is also seen(because that's 2 feet in old money).
If you find 400mm centres, that could still also be 16inches instead(very close to 400).
Ta!You use a spirit level when you hit one? I spoke to guy who said the expensive stud finders he sells are good but not cheap ones. But job and knock on here I remember didn't rate them and used a magnet and pin or something
Sorry mate, but plasterboard has been 1200 (not 1220) ever since we metricated in the 1970s (and did that every mess up the guys who used a folding, non-metric rule back then I can tell you!). Can make quite a difference to finding stuff (or not) over the distance of a wallPlasterboard is usually 1220mm, so 610mm centres is also seen(because that's 2 feet in old money).
More likely that it's a batch of export sized boards that had been dumped on the local market when an export order fell through. The problem is that Gyproc aren't the only game in town. For example there's Knauf (German)..... OK, granted that for the right quantity they'll make you any size you like, but the oddball sizes do tend to be used on more large scale buildings (hotels, conference halls, shopping centres, etc) than domesticsGyproc still sell both...
I have many times seen plasterboarders trimming 10mm off each side of boards with a surform to match what the carpenters have built. Maybe it's a regional thing?
Agreed that it ought to be the standard, but TBH I cannot recall any wall I've framed-out (and in many cases clad with plasterboard) since the early 1980s being on 16in centres - it's pretty much all been 400mm. On the other hand I have more times than that had to add-in additional timbers to carry boards when some muppet has put-in framework on 16in centres (and the boards were 1200...). And that's all over the midlands and north. Hence my comments. Even my local builder's merchants (who were near incredulous at my request for taper edge boards and collated screws as recently as 1992 - they didn't stock them) were selling only metric boards as early as 1987
May seem like a small difference, but that small difference is enough to screw things up completely when trying to locate studs, especially if they are metal and only 35mm wide.400mm is 15.8 inches. Is this what you meant by 400 not being 16 inches. Did you mean that small difference?
In modern domestics you can find either 400 or 600mm centres on joists (I've installed both, 600mm is more common). I find that dry liners can be a bit hit an miss on the positioning of intermediate studs (they are generally installed loose and adjusted into position before being screwed) with only the studs at the edges of boards being in a guaranteed place (because they need to be there to support the joint). Ceilings are pretty much always 600mm centres in my experience. Problem is that you cannot always guarantee that the first stud in a wall running away from a corner will be at 400mm or 600mm - I've seen instances where a wall frame is installed then boarded and a bisecting wall is then tied into the first wall at a non-standard centre by simply screwing through the new frame and already-skinned (on side only) wall into a piece (or pieces) of MF stud on the back face of the PB (this being at the stage where one side of the wall still hasn't been skinned to allow services such as electrical wiring, data cables, etc to be installed). That's why magnets make sense as a way of finding the screwsSo studs are 400mm apart from corner of wall? How about joists?
