No power to boiler
17 Aug 2019
hi, I have no power to my proteon boiler at present. It’s wires into a fused spur 3amp, I changed this and the red light comes on but still no lights or power to boiler. I’ve checked the RCD unit and all switches are up.....
This came about when I looked at the wall mounted thermostat (British Gas rs1) we have had a Nest smart thermostat delivered, I turned off electrics to see the wiring on the old thermostat but it appeared I needed someone with more of a sparky background to wire this up for me. I put the old thermostat back on with all live, earthed, neutral etc back to its original (I took a photo before removing) but I’m now left with no power to boiler?
"No power to boiler". Do you mean the boiler will not fire up on demand but there is voltage present at the boiler ? Or no voltage present at all ?
sounds like when you have re-connected the wires you have pushed a wire in too far and screwed on to the sheathing rather than the wire
on your bottom pic the function selector is set to O your boiler will not give a display in this position
Answer... A designer :rolleyes::LOL:
Not a patch on W/B design dingbats.
