Hello all,
I'm at my wits end...
I have fairly recently taken the plunge and re fitted my entire bathroom. I should probably add at this point that I am not a plumber and before I undertook this mammoth task I had no plumbing experience whatsoever. I hope that this has not now let me down at the final hurdle...
Before starting this job we had no shower and were desperate for one so I took the opportunity of a blank canvas (and it was really blank as I had to rip out every single pipe from the bathroom, most from the loft and all from the hot water cylinder as they were 70 year old galvanised steel pipes) to fit one.
The problem is that after working fine for the first month or so, the pump has started hunting for a few seconds every 5-10 minutes and I can't stop it.
My system is as follows:
2 story house, water tank in loft, shower upstairs, hot water cylinder downstairs in a cupboard in the living room. All pretty much vertically in a line. Cylinder is vented and the pump is a negative head Stuart Turner 1.8 bar twin impeller shower mate. I've fitted it in the bathroom behind the bath panel to avoid noise in the living room. Cold water feed is 22mm direct from tank in loft (separate to taps) converted to 15mm before pump connection. Hot water feed is 22mm via Surrey flange from cylinder and a 600mm gravity loop up to bathroom floor, converted to 15mm before pump connection.
Can anyone tell me what might be wrong or where to look as I'm all out of ideas. There doesn't appear to be a leak anywhere and it's a brand new pump.
HELP!
HELP!
