Is our plumber being honest re which taps will work for our low pressure system?
5 Aug 2008
Berkshire
We have a flat that was built mid-90s. The cold water tank sits above the hwc in the airing cupboard so there isnt a huge amount of gravity but we never had a problem with hot water flow until we changed our taps. The kitchen has a mixer tap, bathroom 1 sink has a mixer tap, and bathroom 2 sink has 2 individual taps. We changed the 2 mixer taps and since then the hot water flow to them is just a dribble. When the cold is added the hot doesnt even flow. The plumber said this is because taps these days are small bore so the bore isnt wide enough to deal with the lower pressure of our system. We asked him before we bought the taps if we should bear anything in mind when choosing taps but he said 'no any taps will be fine'. That plumber is no longer around so we got another plumber in to ask how we can fix this problem. He says we need a direct unvented cylinder so the hot water also flows at near mains pressure. This will cost us several hundred pounds. We asked him 'can you not just fit different taps that work like the old ones used to?' He says no because modern mixer taps are small bore and even a low-pressure half bar mixer wouldnt be up to the job as our hw pressure is so low. We point out that a) the old mixer taps worked fine before, so our hw pressure cant be that low, and b) the hot water single tap in the other bathroom and the bath itself still work fine. He is insistent that there is no mixer tap available that will run hot water through it like the old ones did.
Please advise. He seems like a nice guy, weve used him for other work and hes good at his job and reliable, but what he is saying doesnt make sense to us.
You can still buy taps of traditional design, but you will get better flow through individual taps than a mixer.
Look at Bristan Regency. A very good tap but you might not like the look of it.
If you phone the makers they may suggest others.
On their website I think they indicate which plumbing systems their different taps suit. A very good maker.
Btw I suspect you have unbalanced supply, which is unsuitable for a mixer. Put your thumb over the spout and turn the hot tap on. Can you hold back the flow? Now turn off the hot and try the cold. Can you?
Mixer taps with a single joystick and a ceramic cartridge are particularly unsuitable.
Also ensure that the mixer tap in the kitchen ( and any other tap you use for drinking water ) has separate water ways through the spout to keep hot water separate from drinking water. ( Hot water stored in a cylinder can breed germs when the temperature is below 60°C )
Have isolation valves been fitted to the hot supply pipes to the two mixer taps when they were installed ? If so they may be contributing to their poor performance. As advised above ,some mixer taps are more suitable than others for low pressure gravity plumbing set ups.
If you want to use mixers/monobloc tap with a very low pressure system like yours on a sink or basin, then you need to have what are called low pressure/dual flow. He hasn't advised you properly I'm afraid, either that or he doesn't know the difference.
You can get them, just look for dual flow taps.
Also, many if not most kitchen mixers nowadays come with narrow-bore flexi connectors which further restrict flow.
Full bore copper connector tails are still available as a separate item.
its not just taps the 10mm flexis to some sink taps are very restrictive
