When you refilled from the drain down point, water entered the system and filled the header tank via the vent pipe......sure enough, the tank overflowed when it was full. Its evident here that the expansion pipe is unblocked (thankfully ) and all seems well.
There's no need to replace this pipe, but for the system to be bled properly you will need to replace or unblock the supply pipe to the radiator circuit at some time.
John
Mains pressure introduced at ground floor drain point , and did you see water coming out of the vent into the f&e ,or are you assuming it did because the f&e overflowed ?No, I must have not been clear.
The system was fed from the tank through a valve into the vent pipe not mains pressure.
Also, when filling the system through the drain, water did vent back to tank and them overflowed through the correct pipe to outside the house.
So basically it is venting but not refilling via the feed pipe.
