Today I found the electrics in the kitchen had tripped and the washing machine stuck in mid cycle.
After resetting the electrics the washing machine would not continue with the cycle or perform any new cycle including drain.
From powering on, when I select any cycle the flashing Start LED stops flashing and goes stationary as it should. Than after some seconds it does not start the cycle as it should and instead I get flashing Spin LED/Start/wash option LED’s accompanied with 3 sets of 3 beeps.
I have manually drained the machine and checked for blockages. I have also tried to follow some reset instructions online and that has made no difference. Not sure if they were appropriate for my machine.
I’m guessing it’s not the brushes as than the drain cycle should still work. Also guessing it’s not the heating element as again drain cycle should work. I have read RCD tripping is sign sometimes sign of suspect heating element fault.
Am I correct in my assumptions or does the Bosch handle faults in a different way ?
This leaves me to suspect it’s probably the PCB and possibly the heating element as well. I think this could be more expensive to repair than it’s worth so wondering.
If anyone can help with some further ideas to diagnose the problem it would be appreciated as I’m not best of positions to buy a new machine right now.
