So I just keep pumping? How do I know when the water is out of the EV? And then once it's out do I deflate the EV from the Schrader valve again so that I can then fill it to the correct pressure (0.75 bar)? That sounds slightly counterintuitive, if I release the air from the EV doesn't that just get replaced with water from the system again?doesnt matter where you leave the drain open but you must leave an open point somewhere, think about it, your EV is full of water , you need to get all the water out, then you can start to pressurise the vessel, you will be surprised how much water comes out before you actually start to pressurise the vessel
