Our kitchen tap has been getting loose (when moving the spout) over the last few weeks.
This morning I tried to tighten it with a box spanner (as I have done a couple of times before) but realised that since the last time we did it, a boiler condensate pipe has been fitted, and is now blocking access to the rod (unsure of name) where the bolt is.
I figure the two ways round it are to remove the pipe that's in the way (it seems to have some sort of glue securing the joints), tighten the tap and re-add the pipe, or ask the boiler fitters to re-route the condensate pipe to allow access.
Given the boiler was fitted nearly 2 years ago, would asking them to slightly re-route the pipe to allow access be reasonable? Should access have been considered when fitting the pipe?
If removing the pipe how would I go about it? Should I expect much water to come out?
Any other thoughts on how to go about this? As may be obvious I'm a complete novice when it comes to plumbing!
Picture is below...
Picture is below...
