My Kitchen taps are loose, and move when I turn the spout. I can only just get access to the tightening nut underneath. Can anyone recommend a tool to tighten this nut please? The nut is the long hexagonal nut that runs down next to the supply pipes.
Best to get extra deep sockets, since the nut may have to be reached when there is still a lot of the threaded stud in the way. I think the nut/socket sizes will be around 12mm, but if you get a set around that size, it should cover it.
