This is a pipe coming from the boiler and has become fractured, no idea how the pipe has suffered enough strain to actually cause a split in the pipe but nonetheless it has happened.
Problem at the moment is that it's dripping all over the patio. It looks to be solvent welded and I'd like to replace the corner fitting myself. Is there a product I can use that will weaken the join and loosen the fitting so that it can be neatly pulled off and replaced? Or will this job require the fitting to be cut off?
