I
iDIY
Long story short, I am building a garage with an art studio above it. Planning is sorted and the BCO has told me that other than the foundations which support both parts of the building, the garage level doesn't actually come under building regs for things like insulation etc, BR only apply to the art studio above.
As the dense concrete block cavity walls of the garage level have risen to the height required for suitable head clearance inside I find the roof joists of the garage which are the floor joists of the studio need to join the walls exactly where the HD catnic lintel crosses the doorway. As I understand it you can't point load the catnic lintel so the joists can't sit directly on the lintel.
So would it be ok to cross the vertical inner face of the lintel with a limber bearer and hang the joists from that?
See attached picture of the type of lintel and the proposed solution?
